Disabling Bluetooth causes issues in DJI Fly
12Next >
6218 57 2020-4-2
sbonev
Flight distance : 3665279 ft
Switzerland
as per the title, on Android 9 with Samsung Note 8 when using the DJI Fly app  disabling the bluetooth causes strange issues with the app - buttons for photo/video on RC stop working and the flight mode cannot be changed or displays N/A. Initially i thought it was related to airplane mode, but it is actually bluetooth, when triggering airplane mode it switches bluetooth off, hence the issue. I have been able to replicate it every single time! it really does not make any sense.
2020-4-2
Ingo Sundowner
Flight distance : 914012 ft
I've been flying in airplane mode since November,  no issues with photos because Bluetooth is disabled on android
2020-4-2
sbonev
Switzerland
Ingo Sundowner Posted at 4-2 01:24
well, it is device specific, most probably samsung...so poor coding/testing on part of dev team definitely
2020-4-2
crash1sttime
Flight distance : 1047503 ft
sbonev Posted at 4-2 01:50
Interesting, I have an S6 and S7 and will test this out later, NB Bluetooth isnt disabled by default on Android devices.
2020-4-2
fans13de2c89
Flight distance : 230 ft
crash1sttime Posted at 4-2 02:18
S6 here and airplane mode always...no problems.
2020-4-2
DJI Thor
Flight distance : 13602 ft
Hi sbonev, could you please provide the DJI Fly version info and a video of the issue to me? I will forward your feedback to our engineers to check.
2020-4-2
sbonev
Switzerland
DJI Thor Posted at 4-2 03:06
this is with the latest version 1.0.8, it was present in previous version 1.0.6 also. I will make a video next time i fly, unfortunately i cannot make a video of how the RC buttons don´t work.
2020-4-2
sbonev
Switzerland
fans13de2c89 Posted at 4-2 02:48
probably it is in the newer models after s8, it could be hardware specific also.
2020-4-2
sbonev
Switzerland
here is the video of the issue with both the app and RC. Switching to airplane mode results in the same behaviour, that is how usually try to fly. The only way to avoid it is to switch off bluetooth prior opening the DJI Fly, nevertheless this is an annoying bug.
2020-4-2
ABeardedItalian
Flight distance : 1063107 ft
My s9 a10 still starts non-responsive sometimes, you have to kill the app and restart it for all function to return. When I get connection to the mini I press the camera button first, if it switches to camera then I know my buttons are working. If the mini doesn't respond I know I need to restart the app again, sometimes it's bad enough that I have to restart the phone.
I'll check later to see if it's related to Bluetooth or not but these have been my experiences with the app.
2020-4-2
sbonev
Switzerland
ABeardedItalian Posted at 4-2 04:08
first i thought it was the airplane mode, than somebody pointed out it might be wifi, bluetooth issue, so  i was hoping dji would fix it with the new 1.0.8 version of dji fly app. Apparently that did not happen, so i tried to identify the culprit and it only happens with bluetooth.
2020-4-2
Bloodied_Mini
Flight distance : 145361 ft
Malaysia
sbonev Posted at 4-2 06:22
It's good you isolated this to bluetooth. I'll try it out on Sat and see if this can be replicated.
2020-4-2
m80116
Flight distance : 3264131 ft
Definitely checked and CONFIRMED, Bluetooth is causing the app the stop responding to Flying mode changes: P, S, C. In my case with all sort of other problems including when re-launching the app an MD not connected to RC, which I'll gloss that... and again RC not connected to AC, which HAS NEVER BEEN the case.
So... DJY Fly app throwing random errors but I know mine should be an isolated case since I am still in for an USB OTG cable replacement.
Now... is anybody having problems with Flight Data Center history ? Not only today my flights weren't logged (I never took off though, just started the motors) and have never shown the thumbnail, something that AFAIK has never worked in my case, but I suspect for the whole Android OS enabled devices.
REPORT: reported directly to DJI w/ Fly app, I suggest you all do the same.
2020-4-2
Ingo Sundowner
Mine's an ancient galaxy s6
2020-4-2
fans23214ef8
Ingo Sundowner Posted at 4-2 09:17
...yep, me too...no probs...and 1.08 fixed the aircraft positioning versus my position on the bottom center...did you have that issue?
2020-4-2
sbonev
Switzerland
m80116 Posted at 4-2 09:10
yeah flight center is buggy as hell...uploading works on occasions, usually after many tries and i guess only with the proper alignment of the stars
not sure about the thumbnail, you mean the maps icon on the right side of each flight ?
2020-4-2
captqbec
sbonev Posted at 4-2 09:39
I mean your position versus aircraft bottom center...you know...half circle with arrow...
2020-4-2
captqbec
aircraft versus user icon
2020-4-2
sbonev
Switzerland
captqbec Posted at 4-2 09:43
most of the time i don´t use this as it is not accurate at all, i usually rely on the map...haven´t checked in the updated app, it might be better working, but on the few occasions i flew it was not working. Though i didn´t specifically tried it out so i cannot be certain.
2020-4-2
m80116
Yes. The greyed map icon should be populated with a picture of your flights, supposedly taken from cache or a snap you took while flying. While I've seen a couple of screenshots of the iOS Fly app having this, I've never seen a working one from an Android device.
2020-4-2
m80116
sbonev Posted at 4-2 09:53
It's usually pretty accurate after you calibrate your MD while attched to RC.
Wave the assembly in a figure of 8 infront of you or rotate the assembly in every direction including a complete pitch over, roll over and yaw over.
2020-4-2
sbonev
Switzerland
m80116 Posted at 4-2 11:26
did it several times, somehow my figure 8s are not that good and the first time it was way off, afterwards i think it was more accurate, but in between the app restarts it disappeared...
as for the thumbnails, i would rather get the upload working, can live without the thumbnails, but it is true- if it works on ios, it is an android issue...
2020-4-2
Bomberp
Flight distance : 2644672 ft
Poland
I have got the same problem. I use Samsung S9 with Android 10, but in Android 9 was the same problem.
2020-4-2
m80116
Since today I started the motors twice but didn't fly at all (took off) I don't notice anything new in the Flight Data Center history. I suspect this might be an improvement where motor start ups aren't recorded anymore.
What I've noticed with flight uploads I grant the app its time and my logs always end up being synched with the cloud (fully aware I am losing the .dat files).
2020-4-2
DJI Thor
sbonev Posted at 4-2 04:02
Thank you for getting back with the info, I really appreciate it. The issue has been forwarded to our engineers to investigate. If there is an update about the case, I will let you know.
2020-4-3
m80116
I like this kind of feedback from DJI... we'll see if they actually manage to address the problem in a future update. Thank You.
2020-4-3
jperkmr954
Flight distance : 1228609 ft
Im glad I jumped into this thread before I made a post. Using S9 - Wait until SAT are 12+ / takeoff / and then I usually will switch into airplane mode. I have noticed that , and I can't confirm 100% but I think it might be also, that once I go into airplane mode - I am unable to use the photo button to take pictures. I want to go test this out today again now, so are we saying that: If we fly and don't go into Airplane mode, then the buttons should work correct?
2020-4-3
sbonev
Switzerland
jperkmr954 Posted at 4-3 09:59
you still can activate airplane mode, just make sure you disable bluetooth prior opening dji fly app....
2020-4-3
jperkmr954
sbonev Posted at 4-3 10:08
I'm going to test it out shortly, now that that is mentioned I am not positive that my Bluetooth is on, but I am usually getting out of the car, so it is likely usually on. Thank you for the input - I'm going to test it.
2020-4-3
fill212
Flight distance : 346076 ft
Slovakia
The same happened about 2 times on my Samsung s8, even haven't realized that it can be connected with Bluetooth.
2020-4-4
fificap
Flight distance : 55531 ft
Hi,
That's strange. For me airplane mode on phone is the best way to avoid RC/aircraft disconnection. I use a Samsung S7 ( android 8 i think) and most of the time i take off without touching anything on the phone, then often after some distance i can face disconnection, so i said " Damned, i forget again to put the phone on airplane mode !", i switch to aiplaine mode and no more disconnection. I do not notice any problem with this mode but i will do deeper test next time.
I remember that sometime the RC photo button didn't work, only button on app works (never had problem with video button on RC), may be it's related to bluetooth and airplane mode.
2020-4-5
Bloodied_Mini
Malaysia
Repeated test today. sbonev is right, if you had bluetooth on when you are connected to the drone, turning off bluetooth will make you lose the ability to change flight mode between P/S/C.
In previous test, I had bluetooth off when connecting to the drone. Switched it on and off didn't affect ability to change flight modes.
Phone: Samsung Note 10+
OS: Android 10
2020-4-12
sbonev
Switzerland
Bloodied_Mini Posted at 4-12 00:01
next level is to identify what is the connection of the bluetooth to the flight modes and RC buttons...i don't see any logical explanation so far
2020-4-12
Bloodied_Mini
Malaysia
Tested today after new FW update, problem with switching off bluetooth disables ability to change flight mode still persists. Can someone else test this and confirm?
2020-4-24
sbonev
Switzerland
Bloodied_Mini Posted at 4-24 21:20
but the problem is clearly an app specific issue on android, there is no way a firmware would fix this, only app update...
2020-4-25
Bloodied_Mini
Malaysia
There's a hope that it'll be fixed
2020-4-26
sbonev
Switzerland
DJI Thor Posted at 4-3 00:20
just updated to DJI Fly app 1.1.2 and this issue is still existing. Do your developers plan to fix it anytime or they don't know how? it is 4 updates later and still no sign of any fixes for any  bugs or inconveniences of the app, only app crashes fixes according to the updates description, which sounds kind of not very concrete...
2020-5-19
NatureDigital
Flight distance : 373002 ft
Maybe there are some connection errors when you disable bluetooth
2020-5-19
sbonev
Switzerland
NatureDigital Posted at 5-19 11:39
connection errors to what? how is the bluetooth related to the RC video and photo buttons...or the onscreen button to change the flight mode? In any case it is a serious bug and DJI are not doing anything...for months...
2020-5-19
Bloodied_Mini
Malaysia
Devs are probably working on a solution around the Autel patent lawsuit. Give them a bit of time, afterall, we have a work around for this.
2020-5-19
12Next >
