Montfrooij
Flight distance : 2560453 ft
I don't see much difference.
In fact, the ND filter is only useful for lowering the shutterspeed and that is only needed for faster motion.
PL filters might have some effect, but only when they are in the exact direction relative to that of the sun is hitting the lens.
So if you are a bit off , that effect is minimal.
The problem with drones is that they tend to move, so the angle of the sun hitting the glass will change between shots (while you can't change the orientation of the PL filter).
That is my 'issue' with these filters (and why I seldomly use them).
You should fly back between shots and change the ND density if you have different lighting situations to get a good shutterspeed (for example when you include more of the bright sky in your frame)
And with PL filters it is sort of a guess.
When you move the gimbal up or down OR rotate the drone, you should actually check the PL filter to make sure it is in the correct position (which you can't because the drone is in the sky). |
