Phantom 3 Latest Firmware needed
1744 25 2020-4-14
Dykey
Flight distance : 643 ft
Since updating this morning i have an ESC error which has never applied before.
Can someone advise if the latest firmware is the fix and how do I get it at the moment a perfectly good uncrashed drone cant fly.
Why is the firmware not readily available to download anyone else had this issue?
2020-4-14
DJI Natalia
Hi Dykey, I have sent you a PM, kindly please check it. Thanks.
2020-4-14
Dykey
DJI Natalia Posted at 4-14 04:13
Thanks, Natalia I will give it a go many thanks
Paul
2020-4-14
Max Mayrjhena
Panama
hello i need the lastest firmware... i got the same problem with my phantom 3 professional
2020-4-14
DJI Natalia
Dykey Posted at 4-14 04:37
Paul
Please keep us updated if the issue persists.
2020-4-14
DJI Natalia
Max Mayrjhena Posted at 4-14 13:47
Hi Max, I have replied to your PM, please have a try, thanks.
2020-4-14
Eduardo Silva
Flight distance : 28757 ft
Brazil
DJI Natalia Posted at 4-14 20:36
hello i need the lastest firmware... i got the same problem with my phantom 3 Advanced, Satellites and GPS signal taking too long to appear
2020-4-15
DJI Natalia
Eduardo Silva Posted at 4-15 16:41
Hi Eduardo, I have sent you a PM, kindly please check it.
2020-4-15
Jack_M
Hello I just received the same issue. Would you be able to send the latest firmware. I have a Phantom 3 Advance
2020-4-16
DJI Natalia
Jack_M Posted at 4-16 10:28
Hi Jack, I've sent you a PM, kindly please check it. Thanks.
2020-4-16
fans809aaec3
Chile
DJI Natalia Posted at 4-16 22:26
Hi! I have the same problem.
I have p3 4k and after upgraded  now I cannot connect my rc to wifi. It says problem of authentication.
2020-4-18
DJI Natalia
fans809aaec3 Posted at 4-18 12:56
Hi there, the firmware provided on this post is for P3P/P3A ESC error. Regarding the issue of your P3 4K, could you please restart the aircraft and the remote controller to try the connection again? You may refer to the P3 4K user manual to reset the remote controller Wi-Fi:
https://dl.djicdn.com/downloads/phantom_3_4k/20170711/Phantom_3_4K_User_Manual_EN.pdf
If the issue persists, please contact our support team via http://www.dji.com/support for further assistance. Thanks!
2020-4-19
roca1979
Flight distance : 423 ft
Mexico
hello could you help me please i have the same problem please
Phantom 3 professional
2020-4-20
DJI Natalia
roca1979 Posted at 4-20 22:28
Hi there, please confirm if it is the ESC issue? The firmware package provided on this post is only for fixing the ESC error on Phantom 3 Advanced/Professional. Thanks.
2020-4-21
roca1979
Mexico
DJI Natalia Posted at 4-21 04:06
Hello, the problem is that I do not have a video signal, the screen is black, the RC is linked to the P3P, I can take photos and video but it is only registered in the sdcard and the live signal does not appear on my cell phone.
PD. It is updated to the last version both the RC and the P3P
2020-4-21
roca1979
Mexico
roca1979 Posted at 4-21 06:48
PD. It is updated to the last version both the RC and the P3P[Image]
Dji go
2020-4-21
DJI Natalia
Hi there, thanks for your information. Please insert the SD card to check if the OSD information of the camera is normal or not? At the same time, please check if you have adjusted the exposure value to the lowest value, it may cause a black screen too, you are recommended to try to reset the camera parameters. After that, you may try to change a mobile device and let us know if the issue still persists or not.
2020-4-21
roca1979
Mexico
I have already reset the camera values ​​and I continue with the same problem, I have tried different devices as well as ios and android. I do not know what to do
2020-4-21
djiuser_Cb6OFz2vyZzc9
Flight distance : 116079 ft
Good afternoon.
I have a phantom 3 advanced with the esc error. Could you please send me the firmware update please?
Many thanks.
2020-4-22
DJI Natalia
roca1979 Posted at 4-21 20:56
Hi there, sorry for the inconvenience. Please check if the firmware of the aircraft and remote controller have been updated to the latest or not? If not, please try to upgrade the firmware.
If the issue still persists, please contact our support team via http://www.dji.com/support and send the drone in for service, we'll do the best to help this out.
2020-4-23
roca1979
Mexico
DJI Natalia Posted at 4-23 00:45
Can you tell me what the latest version is as this is not what appears in my RC.
download the last file on the page
2020-4-23
roca1979
Mexico
2020-4-23
Hi Natalia.
I have a p3a with the esc error. Could you send me the latest firmware please?
Kind regards.
2020-4-23
DJI Natalia
djiuser_Cb6OFz2vyZzc9 Posted at 4-23 05:01
Hi Natalia.
Hi there, I have sent you a PM, kindly please check it.
2020-4-24
djiuser_4pEcOYf7nZ0k
Flight distance : 57822 ft
Brazil
Hello Natalia I have a problem, esc status. error after updating to the latest version of the phantom 3pro
2020-5-14
DJI Natalia
djiuser_4pEcOYf7nZ0k Posted at 5-14 17:45
2020-5-15
