Problems with Dji Ronin Sc
19208 32 2020-4-21
Bharat Lama
Nepal
Please help me , I am facing many problem with Ronin Sc , 1. Frimware can't be update, 2. Motor is not working, 3. When i connect gimbal with app it shows 0% battery, even i have charged battery full. without an app i try to autotune but its doesn't work and shows Red light.
2020-4-21
Hi Bharat Lama, sorry for the trouble with Ronin SC, did the Ronin SC connect to the APP via Bluetooth successfully? Please troubleshoot according to the steps below if the firmware cannot be updated.
1. Check whether the version of the app is the latest.
2. Check whether the mobile device is connected to the Internet.
3. Ensure that the mobile device is not disconnected from the Ronin-SC during the update.
4. Please replace the mobile device, restart the Ronin-SC, and try again.
2020-4-21
Bharat Lama
Nepal
Thanks for fast reply..As u say I tried same ways, Really feeling disappoint and scare of my dad
2020-4-21
Bharat Lama Posted at 4-21 05:42
Please ensure there is no other Bluetooth enabled and the connection between APP and Ronin SC is fixed, the battery level is above 20%, then follow the tutorial video below to try again. If there is still no luck, please re-install your Ronin APP or have a try with another mobile phone.
If the issue persists, may we have a video of your operation for further verification?
2020-4-21
djiuser_YLbGqNcvECBi
Paraguay
Buenas me podrían ayudar tengo problemas con mi ronin sc al momento de usar la palanca virtual me salta que no esta conectado el obturador que puede causar fallas y esta todo conectado por mi cámara que es un EOS m50
2020-9-17
Paraguay
2020-9-17
djiuser_qGbmKme1y9lq
My ronin sc isn’t working. It’ll turn on but the joy stick doesnt work I tried auto tuning it n that doesn’t work either I got it last week. I balanced it it said everything was excellent
2020-10-25
djiuser_qGbmKme1y9lq Posted at 10-25 14:33
Sorry for the trouble with Ronin-SC, which camera are you using? Please refer to the compatibility list here and make sure the correct cable is used and setup method is proper: https://www.dji.com/support/compatibility?product=ronin-sc
2020-10-25
DJI Mindy Posted at 10-25 19:36
I got a Panasonic lumix g 7 n I got the correct cord to control my to make it compatible. I used it a couple times. One day I tried to auto tune it n it got to shaking real bad
2020-10-26
djiuser_qGbmKme1y9lq Posted at 10-26 02:51
Hello, as the Panasonic G7N is not on our compatibility list, some camera function cannot be achieved. https://www.dji.com/cn/support/compatibility?product=ronin-sc
2020-10-27
DJI Mindy Posted at 10-27 03:48
It’s not the function cause it was working before. Even if ion got the camera on the gimble the gimble still doesn’t work. Like it’s not working at all the green light just turns on
2020-10-28
And I kno a couple of people wit the same camera n gimble
2020-10-28
DJI Wanda
djiuser_qGbmKme1y9lq Posted at 10-28 03:03
Hello there, we are sorry for the product experience you got with the Ronin-SC. Could you please share any video regarding to the issue you mentioned above? We can help to check it with our engineer to see if any solution can be reach out.
However, as we indicated previously, the Panasonic G7N is not on our camera compatibility list, we may not guarantee the functions can achieved well on the Ronin-SC.
Let us know if you have further questions.
2020-10-29
djiuser_vGrVUf8fAEuG
My ronin sc is also just flat out not work. I balance it I turn it on, and it spins uncontrollably. I have no idea what to do. This is legit my first gimbal. It says the motors arent on. I can't balance test it, I can't auto tune it, lit doesn't do jack all. And the green light just blinks.
2020-12-26
DJI Wanda
djiuser_vGrVUf8fAEuG Posted at 12-26 17:57
Hi there, I'm sorry to hear about the difficulties that you encountered, please send us an email to support@dji.com, provide us with a video so we can help to check the details of the issue, we'll follow up and do our best to help this out. Thanks.
2020-12-27
djiuser_lk5ZBv8DfHRp
I have the exact same problem, motors not working anymore. Battery fully charged, Ronin SC turned on, and then nothing. App shows 0% battery. It used to work very well before. Is there a solution? What can I do?
2021-2-7
fans0f93bf7d
Hi I have recently bought that Ronin SC.  I am finding that when I place my iPhone XR on the hot show to act as active track, the camera nearly always looses track and then spins out of control.  Also the camera is nightmarish to balance with the phone holder, but every time I succeed and then do the balance test, half way through the test  the motors go into sleep mode and I have to literally catch the camera to prevent damage to the lens as it would hit the gimble.
2021-2-17
djiuser_liSs1KItRjvd
India
PLEASE HELP!! Everytime I click on my user profile settings in my DJI app, my Ronin sc stops responding, motors all dead, can't even turn off my gimble( had to slide off my battery grip in order to turn it off)  and non of the buttons nor the joystick working. In short my gimble dies if I click on my user profile settings. what shall I do? Please do reply.
2021-7-3
Malachi Manny Fitten
My DJI RONIN SC keeps jerking and moving upside-down randomly even AFTER I balance it!!
2021-8-21
Brinner Claudio
Peru
DJI Mindy Posted at 2020-4-21 05:33
Hello, I have a similar problem, I have the latest version of the app, I connect with the RONIN SC, in the app it tells me that it is connected, but the battery percentage is 0% (the Ronin is charged to 100 %) and I can not see any parameters of the Ronin and I can not update the firmware either, I leave reference images.
2021-10-22
Brinner Claudio Posted at 10-22 21:12
[view_image][view_image]
Sorry that you're having this issue. Please clean the touch pin between the gimbal and battery to see if the battery level issue can be solved. If the problem persists, please contact our support team through the link below to start a case. http://www.dji.com/support
2021-10-23
AlexB60
Dominican Republic
Bonjour , je viens de recevoir mon dji ronin sc,j'ai un i phone xr.J'ai connecter mon ronin sc au bluetooth de l'i phone , j'ai téléchargé l'application sur le site officiel et j'ai connecter mon compte. Et maintenant l'application ne détecte aucun équipement impossible de se connecter. J'ai essayé de retélécharger l'appli, j'ai essayé avec d'autres appareils qui sont dans la liste de comptabilité, rien à faire cela ne fonctionne pas ! Avez-vous une solution ?
2022-6-2
therayvis
Hi DJI,
A Ronin-SC has stopped working where I work.
Defective Ronin-SC video link
https://youtu.be/5UMKq_6S_E4
It would be great if there is a solution or some support regarding the issues that are being shown in the video.
Best regards,
Ray
2022-7-8
djiuser_umB0YIOYDOYi
Flight distance : 447746 ft
Switzerland
Hello
I bought the Ronin SC but my camera is not compatible.
Is there any solution…?
Thanks
2022-9-19
djiuser_tjvkdisYWW3x
India
DJI Wanda Posted at 2020-12-27 03:00
Hi there, I'm sorry to hear about the difficulties that you encountered, please send us an email to , provide us with a video so we can help to check the details of the issue, we'll follow up and do our best to help this out. Thanks.
Even  im facing  the same proble can u give me solution  on this plz
2022-9-23
India
I'm facing the same problem can you please provide me with the solution
2022-9-23
DJI Wanda
djiuser_tjvkdisYWW3x Posted at 9-23 09:45
Hello, there. Sorry for the late response. May we know more information about your issue?
2022-9-25
LuchoW
Paraguay
Brinner Claudio Posted at 2021-10-22 21:12
Buenas,tengo un problema casi igual a este, a diferencia que el mío se desconecta sólo, sólo se conectar un rato, aparece que tiene batería 0% y seguidamente ya salta un mensaje de bluetooth desconectado... si alguien me da un poco de luz..
2022-10-30
djiuser_OMVsLFvzIhjS
India
2023-1-25
India
2023-1-25
suraj swer
India
plz fix this
2023-1-25
suraj swer
India
2023-1-25
Nelvin Gampal
Philippines
Hello, can you help me to fix my dji ronin sc, recently i experience a trouble when im using a gimbal, when i turn it on, the tilt motor not functioning even the gimbal has already balance, and after turning on it gradually turning, and i dont know what's happen. Ihope someone can answer my questions. thank you
2023-9-24
