Cravenfan
Flight distance : 125256 ft
Just about the same price...so there's that...Pgytech might be a bit tougher?
https://www.pgytech.com/collections/for-mavic-air-2/products/mavic-air-2-safety-case
https://goprofessionalcases.com/dji-mavair2.html
- Pygtech has metal grommets on the lock area.
- Both say waterproof, but Pgytech states 1M under water.
- Both have pressure equalization valves.
- Pgytech: The Mavic Air 2 comfortably fits the following accessories: remote controller ( DJI Smart Controller ), Intelligent Flight Battery*3 ( including the drone's inner battery ), power adapter, battery charging hub, cables, battery-to-power bank adapter, filter, spare propellers. It is also designed with customizable compartments.
- GPC: 1 DJI Mavic Air 2, 1 Controller, 4 Batteries (including 1 attached), 2 DJI ND Filter Cases (Under Drone), 1 Charging Hub, 1 Charger, Cables, 1 GPC LensPen, 1 GPC Micro, SD Card Holder, Spare Props
I think I'm leaning toward the Pgytech unit...as I don't see a need for a 4th battery at this time, anyone else have any thoughts?
