mrkooks
Flight distance : 42359 ft
Costa Rica
Another thing that you can't control ( or at least I haven't found out ) is to set the return home to where the controller is, and not only to where you set it. So if you are flying, and you walk somewhere else and then you hit the update return home location, IT WILL UPDATE THE LOCATION-BASED on where the drone is.. not from where you are, so if you are flying over water, threes or any other funky ground.. be careful .. This app have potential, but at this point looks like is not as complete as the DJI Go 4.. but this doesn't mean that is a bad app. |
