FB: GeoDrone4K
Flight distance : 2676129 ft
Romania
Guys, the decoding of H265 is not so HW consuming as you think...
Is related to the player that use IGP/GPU decoding or CPU decoding...in case of CPU decoding you will get a lag and strange behavior as the CPU is not made for this...I have played H265 on 7 years old computer with INTEL Celeron CPU (waaaay lower than I3), 4 Gb Ram, HDD and video card Nvidia MX...You need a more powerful system for play in 4K on actual 4K displays, but if you adjust the video at screen size and resolution from player, will work.
Try POT PLAYER for GPU decoding and resizing if needed...
Also be advised that your refresh rate must be multiple of video Frame Rate....if you export a video at 30 FPS, you need a refresh rate of 60-90 or 120 Hz....If you have 100Hz at a video with 30 FPS, you will see a lot of micro-skipping in image as display will skip frames in order to adjust it to the refresh rate of screen.
PS. The files from phone are low res (max HD), so will work OK...
PPS. The playback from phone at downloaded movie H.265 is resized at the phone screen size, need a very small computing power. |
