Sean-newbie
Flight distance : 15997 ft
Thanks Deucalion.
I agree that there are options such as controlled emergency landings but CSC is there for a reason and, should its use be needed, I am trying to establish the reasoning behind the ''emergency only'' option and how it is meant to be used. I agree that having the mid air shutdown option readily available is risky but, as yet, I haven't managed to accidentally trigger it with my P3. I have done a mid air CSC with my P3 deliberately, as an experiment, and with height enough to recover but given the fold away props of the mini and without investigating the start up behaviour of the Mini I am un willing to try it with the Mini
This morning I tethered the mini to a ceiling light and 'launched' it then CSC'd it repeatedly. I know this does not exactly match trying it iin open air because once the tether is taut the drone does not descend .....but......
I found that in "emergency only" mode CSC has to be held for at least 5 seconds with the joystick then being released to trigger the stop. I also found that down-and-out seems to work better than down-and-in but maybe that is down to me.
In "anytime" mode CSC needs to be held for approximately two seconds to stop the motors and the joystick do not need to be released. |
