JJB*
Flight distance : 12260774 ft
JimmyPickles Posted at 5-24 12:16
Hi guys, flight data link below. That said, I'm not seeing as much info as I've seen in other posts. Did I miss a step?
I started noticing drifting around the 4 min mark. After thinking more about this the drone must have been yawing as simple sideways drifting wouldn't be visible using the gridlines as the marina was another 2K ft away. As you can see on the map it is difficult to not fly over water in my neighborhood so I try to embrace it!
Hi Jimmy,
It is a pity that this 'drifting' in not recorderd on video, or did you had a screen recording active during the whole flight?
Around 4 minute mark the heading of your MM change, from a steady 32 degrees to 58 to 72 degrees . This with no yaw input!
See line 2391 and further in my chart.
Don`t know why this happend, has to do with your compass my guess. If the heading was disturbed by wind than afterwards the heading was corrected again by the sw, but it did not return to the heading 032. Next 25 seconds, with no input heading remains at 072, position did not change ; steady at 415 meters away from HP.
Mayby the DAT file will give more information about his 'error'.
In the other chart you see this yellow heading line goes vertical at 2400, this indicates a yaw move without yaw input ( only yellow horizontal lines are OKE )
In the polar chart the moment that the heading value changed, and seconds after that, within 1.5 meter craft is holding its postion.
cheers
JJB |
