Flew MM out of range and could not connect again
1984 25 2020-5-24
Droneflier
Flight distance : 1811322 ft
South Africa
I flew my MM to 500 meters away from me at a altitude of 50 meters and lost connection, I waited for 5 minutes and did not hear or see the drone, thought it had self landed in the bush, I located the last possition it showed on the Find My Drone app, alass no drone to be found, 18 minutes later I got back home and found the drone had auto landed back in my yard. LOL, I got lucky this time.
2020-5-24
Deucalion
Flight distance : 103091 ft
Wow. Lucky you.
2020-5-24
Vlas
Flight distance : 1398100 ft
Love the failsafe.
2020-5-24
Droneflier
South Africa
I love my MM even more now
2020-5-24
Francoisd
Flight distance : 66352 ft
you are lucky
The log file would help to understand what causes it not to be back after 5 minutes.
2020-5-24
Droneflier
South Africa
Francoisd Posted at 5-24 08:04
you are lucky
I will down load the file and have a look, just busy polishing the MM and giving it some TLC now LOL
2020-5-24
Woe
Flight distance : 4129268 ft
Lucky indeed.
2020-5-24
GaryDoug
Flight distance : 1264639 ft
Something worked as it should have. I bow to the engineers who made that happen ;-)
2020-5-24
dronespilot
Flight distance : 1392995 ft
There's no place like home
2020-5-24
120ccpm
Flight distance : 1396755 ft
Glad you found it, but I'm not sure how to read your story... drones don't magically find find their way home, they return precisely to the Home Point. So why were you expecting the Home Point to be where you were, when it actually was in your backyard? Post the flight record, if you want people to help you figure out what happened.
2020-5-24
Akirasho
Flight distance : 1644009 ft
dronespilot Posted at 5-24 21:21
… the drone was wearing ruby slippers...
2020-5-24
dronespilot
Akirasho Posted at 5-24 23:16
And 18 mins later it went home
2020-5-25
Labroides
Flight distance : 9991457 ft
120ccpm Posted at 5-24 21:24
Drones don't magically find find their way home, they return precisely to the Home Point. So why were you expecting the Home Point to be where you were, when it actually was in your backyard? Post the flight record, if you want people to help you figure out what happened.
It's no mystery.
Find-my-drone showed the place where he lost contact (because it only shows where the app last had contact).
He assumed the drone had come down there, but it didn't.
It did exactly as it's programmed to and came home after losing signal.
No mystery and no need to see flight data to work it out.
2020-5-25
ichan.id
Flight distance : 54183 ft
Indonesia
maybe it came back home when you're going to search to last position. so probably it isn't took 18 minutes.
2020-5-25
HereForTheBeer
Flight distance : 5381368 ft
Labroides Posted at 5-25 06:10
It's no mystery.
sounds like he was flying in a different location than his back yard but it for some reason returned to his backyard.  that's the mystery people want to figure out.     it is possible that homepoint did not update or record properly if that is the case and reverted to an old homepoint.
my original mavic pro i used to own did this a couple of times and i think more of defective hardware issue with GPS, where lost connection with GPS module very briefly like bad solder joint and caused it to bug out.  usually when it did this it would update to drones current location but was very rare time where it would update to an old location i last flew..
2020-5-25
Droneflier
South Africa
Nothing to figure out, I flew the MM away from me and it lost connection with the controller, I tried everything I could to get the controller to connect and it would not due to the MM being out of range. The MM took to long to return and I panicked and went and looked for it using the Find My Drone function on the FLY app. When I finally arrived at the spot where the app showed the last point of communication with the drone, two kids said a drone stopped above them for a while and then flew back in the direction it came from. Obviously it worked on the RTH function as it should of, I had however been in to much of a panic to tough it out and wait to see if it would return.
2020-5-25
Droneflier
South Africa
It's no mystery.
I flew the MM from my back yard and updated the home point where it returned to. To explain the 18 minutes - this is the time it took me to drive to the location on the Fly app look around for the drone, speak to the children and then finally return to my house, Prior to me leaving to look for the drone it felt like I had waited for 10 minutes without hearing or seeing the MM, due to my panicked state it was possible a couple of minutes at most.
2020-5-25
Droneflier
South Africa
I hope this has cleared up my story, I was so happy to be re-united with my drone I had to stand on the roof top and shout it out LOL
2020-5-25
Occams Razor
Flight distance : 488196 ft
If you love something set it free. If it comes back it's yours. If not, it was never meant to be
2020-5-25
120ccpm
Droneflier Posted at 5-25 09:18
Got it. You said the AC was 500m away when you lost control and you waited 5 minutes for it to come back, so it sounded like it went somewhere else (which turned out to be your backyard). Maybe it was facing some headwind and took a long time to come back, or maybe what felt like 5 minutes to you, was more like 1 minute... :-)
2020-5-25
Labroides
HereForTheBeer Posted at 5-25 06:37
No, that's not possible.
As soon as the drone gets GPS, it records a homepoint.
And there is no chance of "reverting to an old homepoint" as old home points are completely lost as soon as you turn off the drone.
When you power up, it has no old home point.
That's impossible as explained above.
Examination of the recorded flight data would show what really happened.
2020-5-25
HereForTheBeer
Labroides Posted at 5-25 17:36
not interested in what you think is or isn't possible... just telling everyone what happened before and that it is possible, regardless what you beleive
2020-5-25
Labroides
HereForTheBeer Posted at 5-25 20:20
I'm not interested in your ignorant thoughts and misinformation.
I was just pointing out the facts for anyone that might have been confused by the nonsense you wrote.
There's no uncertainty in how GPS and homepoint recording works.
It's extremely easy to test and demonstrate how incorrect your ideas are.
2020-5-25
hallmark007
Flight distance : 9827923 ft
You need to lay off the beer, that is the most ridiculous thing I have ever heard on this forum, just as well his last flight wasn’t in France ;+)::::::
2020-5-26
HereForTheBeer
unfortunately for the two trolls (whom are the same people FYI), they just dont understand the reality of programming and interaction between HW and SW. yes it is very possible, has happened to me on several occasions, you cant tell me what i did or didn't see and encounter, you were not there to witness it.  the GPS module was increasingly flakey on my mavic pro before i sold it, it was commonly re-updating its home point to current position in the air or throwing "navigation system error" without going into Atti mode then reverted to last good homepoint moment later, usually last flight's HP.
2020-5-27
DJI Stephen
Hello there Droneflier. Thank you for reaching out and for sharing this experience with us. It is great to know that you were able to retrieve your DJI Mavic Mini. Before your next flight kindly please check the drones status. Again, thank you and have a safe flight always.
2020-6-3
