Labroides
Flight distance : 9991457 ft
Does anyone think an aircraft firmware upgrade might cure this problem?
Probably not and it's always a good idea to identify the cause of the problem and then address that, rather than trying random things that are probably unrelated.
OK - Here they are, but I don't see any info for stick inputs.
It's all there .. if you know what to look for.
Regarding your flight data posted above ...
1st flight
No GPS until the last two seconds of teh flight and the right stick was not pulled back in the last two seconds.
2nd flight
Without controller shows no joystick input data (because tehre were no joysticks
Next 3 flights
Without GPS, there's no way to tell if your drone was moving backwards, forwards or sitting still.
If you want to crack the mystery, go outdoors, wait for GPS before launching and do a proper test flight and come back with data from that flight. |
