Hisfy1969
Schistermin Posted at 6-8 01:44
Use the Android File Transfer application. When you start up the Controller and it will show the USE USB to screen, now you need to select the "Transfer Files" option. When you do that, the controllers folder scheme will pop up which will allow you directly access to all the folders to transfer any screen shots, videos, etc, that are saved in the controller.
Btw, which laptop are you using? Can you suggestion some laptop, I am looking to get one. I do prefer gaming laptop.
Yeah, I need to try that. Will let you know if that works.
I am using the Razer Blade 15. Sure. I saw this guide which mentioned good options that you can consider.
