I recently bought a Mavic Air 2 and got an update for the DJI Fly app which brought it to version 1.1.4. In the release notes it states that there is now a Target Scanning toggle in the Control setting. I've updated the app on 2 cellphones and a tablet and none of them have the toggle anywhere in the settings. Has anyone found the toggle or is just not there for some reason?
Nobody has seen it in the app it is likely awaiting the Air2 getting a firmware update. DJI representatives here don't have an answer only commenting watch DJI SM channels for any update.
-Adds Target Scanning toggle in Control settings. When enabled, aircraft will automatically scan and display targets in the Camera View (only compatible with Mavic Air 2).
Really.. What is Target?
Îs working already for Android starting 1.5 update, is scanning for persons and Mark with X's..
If you wave at camera, will consider that you are Target and will keep camera on you like Active Track.
The scan application that I usually use is CamScanner which is downloaded at TechBigs, you are having problem with a similar app that can use it instead, free download link https://techbigs.com/camscanner.html
