Lens/gimbal cover option for pocket with wide angle lens attached
535 3 2020-6-13
cEQtBhqjyKJB
Has anyone found a lens/gimbal cover option to use with the Pocket when a wide angle lens (I have the freewell wide angle lens) is attached to it?... to minimize having to take it on and off all the time?  I have tried various lens cover and all are too small and cannot attach properly when the wide angle lens is attached
2020-6-13
Robb OConnor
I may be wrong and please someone correct me if I am, but I thought the osmo should not be powered on with wide angle lens fitted and should only be added after power on due to strain on the gimbal.
2020-6-14
fansfe82067d
As I recall it, that problem was fixed by a firmware update.
2020-6-14
DJI Stephen
Hello there cEQtBhqjyKJB. Thank you for reaching out and for sharing this inquiry about a wide angle lens cover for the DJI Osmo Pocket. I hope that you will get the best recommendation from our DJI member who owns the DJI Osmo Pocket and who used the said lens. Thank you and stay safe always.
2020-6-21
