Did I brick my P4? Firmware issue and Ipad Mini 2 DJI GO 4 problem
789 1 2020-6-19
PHREAKTOR
I have been flying perfectly for a week now using my p4 an DJI GO 4 on my iPad Mini.  Occasionally the error message statin "The current device cannot use DJI GO 4" until I powered on the P4 and it would work fine with no issues whatsoever.  Today, I went to fly and when I logged in to DJI GO4, I noticed it said there were firmware updates for the RC and AC.  I tapped the one for the RC and it started beeping 4 timess in rapid sucession. THen the screen went to the error screen described above.  The drone has rapid yellow LEDs indicating it is not paired.  The RC has a cyan/light green status LED and the last white LED is blinking while the other three are solid.
The RC doesn't power cycle as normal now either.  When I press Power on the RC, all 4 LEDs blink and then I hold the POwer button and it powers off, but when I press it again, it goes right back to the 3 solid/one flashing status as described earlier.  I tried to update the drone firmware to the latest version in DJI Assistant 2 and it fails at 99%.  Now the DJI GO 4 app only displays the error screen, so I cannot access the settings.  I read somewhere that the iPad Mini 2 is not compatible with the app, but it worked fine until I attemtped to update the firmware.  Is the RC bricked?
Can anyone please help?  I'm super bummed I can;t fly today because my Dad is here and wants to see it.
2020-6-19
PHREAKTOR
Currently chatting with Support.  They are saying it was caused by the iPad being incompatible, but that does not explain why the AC FW won't update.
2020-6-19
