Mark97564
Flight distance : 2067749 ft
Works fine for me.. I can even use the naza assistant app using the dji ground station .. I can plug the but module into the naza can bus port and use the naza app or I can connect the ground station to the naza can bus port and plug the btu module into the ground end and either use the iPad ground station app or I can close the ground station and open the naza assistant app and then have a 2000 meter range when using the naza app.. It gives you 800 to 1000 meters out of the box but if you put a higher gain antenna on the ground end I'm getting 2000 meters with out a issue.. You do have to initially plug the btu module into naza and then connect naza to the computer and open the naza assistant on your computer and then go yo the tools tab and select reset btu module. Then unplug naza and the battery for the copter and plug the battery in and then connect with your iPad..
My btu module was brand new and I still had to reset it yo it's defaults send then I opened the app and it walked me thru setting the Bluetooth password and naza passwords
Hope I've helped |
