[Feature Request] Wind data in the app
2852 19 2020-6-25
dsvilko
Croatia
Mavic Mini allready calculates and saves the wind speed and direction (both are available in the DAT log file). I would very much like to see both values from inside the DJI Fly app.
2020-6-25
Renato61
Flight distance : 168163 ft
I agree
2020-6-25
Sean-newbie
Flight distance : 15997 ft
What's the column heading for this information in the dat file please? I assume you are looking at the csv version of the file
2020-6-25
22340179
Flight distance : 6763835 ft
It doesn't calculate wind speed. It calculates the power requires to counter the wind to maintain it's position. When it is using a lot of force to counter a strong wind you get the strong wind warning as a result.
Just get a wind app on your device...
2020-6-25
dsvilko
Croatia
From the available data Mini is able to calculate the actual wind velocity in m/s and write it down in the log file (Wind:velocity column if I remember correctly). Judging from the smoothness of the resulting graph, the calculated value is quite precise (much better than 1m/s). No weather app can give you accurate real-time wind speed information at your exact location and altitude with that kind of precission.  The actual number would be much more usefull then a simple binary safe / not safe indicator.
2020-6-25
DJI Stephen
Hello there dsvilko. Thank you for reaching out and for sharing you insights with regards to this matter. I will cascade this thread to the designated DJI department for further attention. All significant suggestions or requests for the DJI Mavic Mini and with the DJI Fly application will be implemented after the evaluation of the DJI Engineers. For the latest updates on DJI please stay tuned to our DJI official website at www.dji.com. Thank you for your support.
2020-6-25
virtual
Flight distance : 4897142 ft
Czechia
Good idea!
2020-6-26
Richard Hopkins
Flight distance : 923406 ft
I agree, Great idea, hope they will listen!
2020-6-26
mathogre
I'll amplify this.  I'm very interested in knowing current winds aloft in real time.  I just got my Mavic Mini, my first drone, less than two weeks ago, but I've been working in r&d for many years.  I've worked with wind data from surface to 30,000 meters.  I'm looking at pushing a project at work that would help understand micro meteorology in an urban setting.  I understand wind velocity data is in the .dat files, and I will be looking at mine in the next days, but seeing current wind at altitude in real time could be a big help to me and obviously others.
Thanks for any further consideration in this request!
Graham
2020-11-14
JohnLietzke
Flight distance : 3125968 ft
I definitely agree on adding wind resistance to the app. It would be especially useful for head and cross winds.
2020-11-15
oldhasbeen
Tilt angle and direction are basic parameters for any quadcopter. When hovering this data equates to wind speed and wind direction. I have suggested to use this many months ago and a
DJI robot promised to "cascade" this to their engineers. Result? zilch!
I would be surprised if DJI engineers did not have this obvious idea themselves since years.
It would however lead to less lost drones (remember no warranty or care plan without presenting the drone). Not good for company revenue. It would also help to empower the user. Not good for authoritarian mind sets which need obedience - not thinking about things.
2020-11-15
djiuser_1CLSIXmPRaPm
Flight distance : 316421 ft
oldhasbeen Posted at 11-15 17:51
I would love to see this too! Ideally with a wind direction indicator right on the screen!
(I just lost my drone due to wind; wind rotated drone while I was returning home, I didn’t notice fast enough and crashed into trees...
2020-11-20
Labroides
Flight distance : 9991457 ft
djiuser_1CLSIXmPRaPm Posted at 11-20 02:28
How did the wind "rotate your drone"?
2020-11-20
A J
Flight distance : 13926112 ft
+1 suggestion
2020-11-20
Cients
Flight distance : 5537369 ft
Portugal
2020-11-20
vortex19
dsvilko Posted at 6-25 20:39
I can’t see how this could be very accurate. In order to calculate accurate wind speed, you need to know your ground speed (which you can derive from GPS data) and your air speed which is not available to the drone. Any wind speed calculated from tilt angle and power used could only be very approximate, at best. For those saying a wind velocity readout would help to eliminate strong wind problems, you already get a strong wind warning from the app. Why do you need to know more accurately what the wind velocity is? It's like having an oil pressure warning light come on in your car. You don't need to know specifically what the pressure is - it's enough to know it's outside of the parameters set by the manufacturer.
2020-11-24
oldhasbeen
Wind speed and wind direction information are essential data for any aircraft and can be derived from tilt angle of the drone during hover.
Take off - go to intended altitude - hover a few seconds - drone will take on certain angles to remain in place. No wind and drone sits at zero degrees. Any wind will result in appropriate fighting angles and the IMU data can be interpreted as wind speed and wind direction.
This is very different to the implemented alarm that does not have any tangible information on wind speed or direction.
2020-11-25
vortex19
oldhasbeen Posted at 11-25 12:05
The wind speed derived from tilt angle can only be very approximate, at best. What about when the blades become damaged or worn and the tilt angle/power has to change to compensate?
"This is very different to the implemented alarm that does not have any tangible information on wind speed or direction." How do you know this? How else would the alarm be triggered?
2020-11-26
oldhasbeen
Tilt angle determines direction and speed of movement. No movement = tilt angles are zero. IMU works very precise to keep drone in GPS determined spot. Even slight wind will cause tilt to counter drifting off location. Tilt is direct expression of counter movement caused by wind. Damaged blades will force change of rotational speed in respective motors - exactly to achieve the needed tilt. Even if the accuracy would be "only" 10 % it would be a tremendous aid. An oil pressure switch tells that a pressure limit is breached - after the event that caused it. An oil pressure gauge allows to monitor, manage and prevent problems. Translate this to the proposals of the thread.
2020-11-26
walkabout1470
Flight distance : 4583891 ft
Portugal
vortex19 Posted at 2020-11-24 12:39
For starters... Strong wind is one thing... Very strong wind is another... and it doesn't even give you a direction!
2023-5-10
