ambambcopter
Sorry to see things went pear shaped for you.
What altitude was pre-set in the return to home settings, 25meters?
It's possible 'it' thought it was more than 20meters from home point.
And dependent on the programme tolerances, the difference may only have been 0.5meter.
So decided to climb to pre-set height.
I assume from your description that the take off was from a relatively confined with trees location.
Which in the scheme of things doesn't allow the bird, or you, any leeway if the RC link goes down or misbehaves.
And possibly being able to override the RTH many many times, as you say you have.
Lulled you into a false sense of security. |
