Switching from Smart Controller to original controller
473 1 2020-7-9
Rlynxgolfermsn.com
Flight distance : 8215 ft
Have the Mavic Pro 2....Upgraded to the Smart Controller....no problem pairing...went to switch back to the original controller from smart controller and could not accomplish.
In the doing so I had a time getting smart controller back paired to the mavic pro 2.
Only reason to switch back is that the original controller I had the flight simulator. Which I believe the smart controller app does not have a flight simulator.
Like the simulator to practice maneuvers and getting good at stick manipulation as to become absolutely second nature.
I am afraid to try repairing original controller now do the fact a may not get the Smart Controller back paired then the Drone is inoperative.
Please any suggestions
2020-7-9
TrevorSK
Flight distance : 1547713 ft
When you get things figured out, you should do a range test. I have a smart controller and I suspect that I don't have as good of signal at distance. I only have the smart controller though, so I can't compare
2020-7-11
