run dji simple app
1025 3 2020-7-16
djiuser_lK2EjhbnUVAh
Lebanon
I have one more question,
I will try to create android simple dji app so I install the demo from this link https://github.com/dji-sdk/Mobile-SDK-Android.
I create an app and I get key and I put it in AndroidManifest.xml
I run the simple app in my android (Sumsung a7 2018) as you said, but I obtain this problem.
Please find attached (SDK Registration Failed. Please heck the bundle ID and your network connectivity … )
What can I do ??
2020-7-16
kv886
When you create an APP key you need to fill in the package name. It should be the same as your android project.
2020-7-17
DJI_Lisa
When you generate an app key for your Android MSDK Sample app (this goes for UX SDK too) the "bundle ID" has to exactly match the package name already listed in the sample app found here in the Android Manifest: https://github.com/dji-sdk/Mobil ... AndroidManifest.xml
You can see here where I generated an app key for the Android MSDK Sample App that the Bundle Identifier matches the Sample Apps package name and only the App key # is different:
This is a common Android gotcha and is the opposite from running an iOS MSDK or UX SDK sample app, where the bundle ID has to be different than what is found in our sample app.
2020-7-20
Drone Inspect
Flight distance : 204554 ft
We need a dji android app developer!
2021-7-29
