Sean-newbie
Flight distance : 15997 ft
Could it be that the mini's flight record do not show up in the go4 app because at a guess the are stored in a folder not accessed by the Go4 app.
Each app creates its own directory structure, as shown in the attached screen capture, showing DJI Go, DJI Go4 and DJI Fly.
This also suggests a POSSIBLE solution. Using a computer copy the individual flight logs from dji.go.v5\FlightRecord to dji.go.v4\FlightRecord .................BUT......COPY BOTH SETS OF LOGS TO YOUR COMPUTER FIRST so that you have them backed up. It might be that the copied flight logs from another app would cause Go4 to crash. I CAN NOT CONFIRM THAT THIS WILL WORK, or, whether it will crash the G04 app, this suggestion is pure speculation.
But I recollect I have moved flight logs to storage, wiped the app, manually removed its directory structure (which uninstalling the app does not do), reinstalled the app, copied the flight logs from storage into the relevant folder and they worked.
