P4 MULTISPECTRAL Release Notes (08/06/2020)
DJI Support
Flight distance : 2408 ft
Overview
  • Date: 2020.08.06
  • Aircraft Firmware: v00.00.0136
  • Remote Controller Firmware: v00.00.0136
  • DJI GS Pro App: v2.0.12
  • DJI Assistant 2 For Phantom: v2.0.10
  • DJI Terra: v2.2.1
What’s New?
  • Added two options for color map settings and range configuration for the rendered display color scale of the vegetation index.
  • Added notifications for the number of battery cycles.
  • Video recording for both RGB imaging and multispectral imaging is now supported.
  • Optimized algorithms of the spectral sunlight sensor to improve stability.
  • Optimized GNSS redundancy backup so that GNSS can still work normally if there is interference in the L1 frequency.
* V2.0.12 or later of DJI GS Pro is required. Pay attention to DJI GS Pro version updates.
Notes
  • The aircraft cannot be downgraded to v00.00.0130 after this firmware update.
  • After updating the remote controller with this firmware version, the remote controller can only be used with the P4 Multispectral aircraft.
  • Make sure that the firmware for the aircraft and remote controller is up-to-date and the firmware for the D-RTK 2 Mobile Station is v02.02.0505. Otherwise, they will not work together.
  • Using this firmware with a version of DJI Terra older than v2.1.1. is not recommended, as some functions will not work properly.
2020-8-6
JetSam
Flight distance : 3462946 ft
Send me a Multispectral for free to test Good info
2020-8-6
JetSam
C`mon
2020-8-20
brianeeberhardt
Flight distance : 99498 ft
Yeah, same here. Many applications for search and rescue in my department.
2020-8-20
djiuser_cDhCre6ml8Gy
Portugal
"Video recording for both RGB imaging and multispectral imaging is now supported."Is there a way using one of the SDK's (MOBILE SDK, UX SDK, ONBOARD SDK, PAYLOAD SDK, WINDOWS SDK) to remote download the recorded multispectral imaging?
2020-8-31
GDimitroff
Bulgaria
Hello to all
My question is to DJI Support do you working on developing of vegetation calculation index becoure for the farmers will be very important information not only to see some value but so see what part of the area is with minimum NDVI and ect. ?
2020-10-7
