Johan97
Flight distance : 37201217 ft
Sweden
sbonev Posted at 8-9 01:47
actually it doesn't know where it is as the gps is not working, so it is not strange to show wrong distance, if you check beginning of the video you can see it was close to launch point where it landed - see the small grove on the left right before forced landing.
Please stop speculating, i had all parts fully functional but the voltage reading, im not running with a stock battery as you hopefully understand....the BMS normaly handling the voltage telemetry snapped after take of, but i know the battery can do around 55-58 minutes, however the wind conditions made this flight time not enough to return all the way home this time... |
