Colbyashi
Thanks for the reply. I did a clean install of the app with no improvement. I also tried installing the DJI GO app on a different device and had the same results, sadly. I also can't switch between photo and video mode on the, app because all those buttons are grayed-out. I posted a picture of the lights thinking they might mean something? I don't remember what the different combinations of green / yellow / red lights under the props mean. I guess if the configuration in my attached picture is normal then ignore that.
At this point I'm thinking it's an issue with the onboard camera system and not the app or RC. The only major thing that happened between the time when it worked and when it didn't, as far as I can remember, is I did a firmware upgrade. As I mentioned earlier, swapping firmware versions doesn't seem to make a difference. I've actually had a handful of issues just related to attempting those upgrades / downgrades today, but those are not particularly relevant here.
I'm thinking, short of taking my bird to a shop to get it diagnosed, I'm outta options. Any other ideas would be much appreciated, though. |
