Sean-newbie
Flight distance : 15997 ft
If you run the txt file through CsvView or probably "TXTlogToCSVtool_general.exe" and output the results as a csv file, then open that csv file as a spreadsheet ( I am using Excel) (Microsoft Works 'loses' a lot of the headers) I find the remote controller serial number in two columns,
1st under " RECOVER.rcSn" = column 237 / IC &
2nd under "DETAILS.rcSn" = column 265 / JE.
BUT the serial numbers are not always present. I have been swapping controllers and am now trying to work out which was which, and some, it seems, haven't written the RC serial number to the txt file. I am beiginning to wonder if it's a lack of updates causing the 'loss'. Ditto battery serial numbers. I haven't tried the DAT files yet.
the battery serial number is in 238/ID & somewhere else,
the charge count? 111/DG,
the battery production date? 121/DQ,
the drone#s activation date? 235/IA
the corresponding DAT file number 210/HB
Incidentally CsvView puts the RC serial number and some other 'goodies' in a small table on the 'front page' of the results.
