Lost signal after completing a Courselock
815 7 2020-10-6
Cacike47
Flight distance : 3268530 ft
I just spent the last 20 mins searching on the forum for a way to access my MA2 flight log files. Is it only Android devices that can access the flight logs?
Please look at the attached video file and see if there’s anything to explain how, I lost signal after completing a Hyperlapse Courselock?
I always download my videos off my MicroSD card and the cache on the drone does not show yesterday's flight data. Check out the “Recco” video from yesterday's flight; I lost connectivity for over 4 minutes over water. The Distance was 2,208 feet and Height was 108 ft.
I have flown from this spot many times and never lost my signal even when I have travelled significantly farther. No matter what I did to activate “RTH”, it would not react; there was mostly no sound either although the “Manned Aircraft Nearby” message would appear. At one time, an audible message came on that the drone was too near even though the height was still 108 feet and no aircraft was visible. Miraculously, after four (4 ½) long minutes, it finally RTH'd on its own, only after trying to get it to go home multiple times by pressing both the on-screen and controller buttons.
But no dice, it would not recognize any of my commands. After getting the drone back, I decided to calibrate the compass but it would not calibrate. I decided to wrap up it and find out what happened. Thank you for your help.
2020-10-6
Montfrooij
Flight distance : 2560453 ft
Hi!
You might be better off posting your question in the 'products' section of this forum.
That is way more active.
2020-10-7
Cacike47
Montfrooij Posted at 10-7 03:45
Hi!
I just wanted everyone to know what happened and if they had this lost signal experience.
I'm new to this forum Thank you for letting me know
2020-10-7
DAFlys
Try uploading your log here - http://phantomhelp.com/logviewer/ - the site also has instructions on how to find it.
2020-10-9
A J
Flight distance : 14103563 ft
Cacike47 Posted at 10-7 07:51
Thanks for sharing your experience and good luck
2020-10-10
Cacike47
DAFlys Posted at 10-9 01:38
DAflys, thanks to your suggestion, I was able to download the flight records. Thank you!
2020-10-15
DAFlys
Cacike47 Posted at 10-15 09:23
No problem.
2020-10-16
A J
2020-10-17
