cheddar-man
Flight distance : 44062 ft
Unfortunately Decoys, LiPo's do not like being left alone and should never be allowed to fully discharge.
Have you a volt meter, can you measure the voltage across the two big terminals. If this is below about 4.5 volts, 1.5 volts/cell, it is possible that the battery is "asleep" and can be waken up with certain chargers.
Measure the voltage. Put on charge for an hour and check the voltage again. If it's going up you might be all right, continue charging. Do not leave the battery unattended while charging - put in fireproof bag if you have one but at least leave it on a non flammable surface. |
