roy
Plug it into the assistant and go to the battery tab. Check the rating of each of the cells. Balanced Lipo cells are very important. If one is way off then that cell may be bad or damaged and the only option is to replace. If all cells show same or very very close to same then try discharging the battery Dow to 8% but never fully discharge as that is bad for lipo cells. After its depleted fully charge. See if you get a 4 Led'S. Then hold down the power button on the battery 5 seconds till it blinks and the see if you get 4 Led's which indicated the battery has 80-100% of usage left. Page 9-10 of manual gives this info. After that give it a try and see what time you get out of it by flying close so you can land if need. Hope this helps. |
