Mini Mavic manual t/o with custom control selected
460 7 2020-10-11
Jetmic
Flight distance : 29131 ft
Denmark
Hi All.
Anybody knows how to use manual prop control on the mini for takeoff, when custom control mode is selected ?
Cheers
2020-10-11
Montfrooij
Flight distance : 2560453 ft
Hi!
You might be better off posting your question in the 'products' section of this forum.
That is way more active.
2020-10-11
Jetmic
Denmark
Thks for the hint!
2020-10-11
A J
Flight distance : 13926112 ft
It's standard for all flight mode options - both sticks down and out simultaneously to arm the motors then push up on which stick you have selected as the throttle to take off.
2020-10-12
Jetmic
Denmark
A J Posted at 10-12 11:02
Actually when you reverse climb/descent eg. On the right stick in custom mode, you also need to reverse the movement of the right stick to arm the motors - I just realized.
2020-10-12
A J
Jetmic Posted at 10-12 13:06
Cool - thanks for sharing - think I'll stick to mode 2 after all these years of flying
2020-10-12
Jetmic
Denmark
A J Posted at 10-12 22:32
Yes, dont change something that works for you :-)
2020-10-12
A J
Jetmic Posted at 10-12 22:55
Good advice
2020-10-12
