levelUP Posted at 10-15 08:25
The included charger probably. As i've lost mine I can't charge it. Other wall adapters, like the one for my phone, didn't work.
Really? So this is like the Smart Controller in that you can not buy a spare charger? Surely there have to be options...
you can use any USB C charger that has Power Delivery, make sure the charger says PD on it , any cheap PD charger from Amazon should work. thats what i use, i even charger my Ronin S from a PD power bank
RickyBat Posted at 10-15 13:32
KS-6 Posted at 10-15 14:45
But is it USB-C on the brick end or USB standard? When I look up the cord on DJI's site it shows C on one end and regular on the other.
Is this going to work? https://www.amazon.com/gp/produc ... 0_s00?ie=UTF8&psc=1
yes that will work as long as you have enough watts, which that brick does it will charge, from experience as long as you have 18w you should be fine. if the cable is USB C on both ends make sure you have a brick with power delivery
Hello there levelUP. I am sorry to know that you have lost your DJI Ronin S power brick. You may try check our DJI Where To Buy platform on this link ( https://www.dji.com/where-to-buy ) to see if the said power brick that you need is available. In addition, I hope that you can get some recommendations from our DJI Co pilots with regards to this inquiry. Thank you and please be safe always.
DJI Stephen Posted at 10-15 20:18
