JJB*
Flight distance : 12401030 ft
Uh, contradiction pur sang! longer flight time AND more batt power consumption..... NOT
【Advantage】Stronger Pulling Force than the plastic and 2 blades carbon fiber 8743 props on quad. Flight 3-5 minutes longer than the standard 8743 props.
【Performance】Flight Smoother and Immediately respond to your instructions,reach wherever you want. NOTE:Use in a normal environment will cause the motor to heat up is more serious and the battery power consumption greater than the original paddle, please confirm whether it is suitable for your own usage require before buying; |
