djiuser_IHwMWjx79VYH
Belgium
Hi,
(I have posted this in other channels in this forum as well, took me some time to figure out the correct channel... sorry for that).
I have issues getting a HDMI stream to the DJI Pilot app using a M600 drone.
We have developed a custom payload that connects to the drone through HDMI. We have developed a custom application on Android to control the payload, using the OnBoard and Mobile SDKs. We can successfully see the HDMI stream in our application.
We also see the HDMI stream in the DJI Go application on Android. However, we don't see the stream in the DJI Pilot application.
We use in both applications (and our custom application) the same settings, namely
* Bandwidth allocation LB: 100%, EXT: 0%
* Video Output: Enabled
* Enable EXT Port: Enabled
* App Output mode: LB
* Output port: HDMI
* Output mode:
DJI Go: LB
DJI Pilot: This option is not there, only [Source 1 only/Source 2 only], but either don't work
* Output format: 720P60
Am I missing something here? How can I solve this?
Best regards,
Bart
