justinlee1
This doesn't have anything to do with aftermarket props per se, but it has something to do with the increased lift of the longer props compared to the original ones. I'm having issues with a different quad, but I have the Naza-M flight controller. I've been successfully flying Graupner 10x5 carbon fiber props for a couple of years and just experienced the same type problem when upgrading to 12" props.
As far as I can tell the Naza flight controller has default gains set for a particular prop size and weight. Deviating from this requires the gains to be adjusted, however it's not intuitive as to which gains would offset persistent climbing. Intuition would suggest BASIC GAIN > VERTICAL, but that doesn't seem to do it.
I've seen this issue reported here and elsewhere, and respondents either hate on the Naza, blame it on something unrelated like the compass or IMU. If they do hit the dartboard it's usually something vague and less than helpful, as in you have to adjust your gains after changing prop size. I'm not criticizing that answer, but think it would be tremendously helpful if someone could clue us in as to WHAT gains should be changed and in what direction when increasing prop sizes.
