Mark The Droner
Flight distance : 2917 ft
The P2V's FPV wouldn't be any worse than the P2V+, but neither can compete with the P3's FPV which is in 720p HD and is transmitted in Lightbridge rather than Wifi. If you look on the app, there is a way to change the quality of the FPV on the P2V series. IIRC, the range is 320/15 fps through 640/30 fps. I think most people use 320/15 because in theory you can get better FPV range since less data is moving down.
Good luck |
