If you ask me... the Mini 2 almost killed the Mavic Air 2. With DJI launching the new Mini 2 and all its new specs, unless you have professional needs, you almost don't need the Air 2 anymore. The Mini 2 can do almost anything the Air 2 does, except for one key feature... Active Track. But in my opinion, that's it. If you don't even use or need Active Track, there is no reason to buy the Air 2 anymore. The Mini 2 is so good that it can be your go-to camera drone. It has wider panoramic shots, a lot cheaper, no registration required, same stability as the Air 2, it just does the job well. If you don't mind the lower specs shots as well as the missing ActiveTrack feature, you're golden. You guys agree? What do you think?
