Rigworker
Flight distance : 52303 ft
As Scotty said, you can use foil to block the GPS signal. Still not quite sure why you need to though. I just did a test indoors with my P3. Same as you with the satellites dropping in and out. When i lose the required satellites, it goes to P-OPTI and returns to GPS when the satellites return. I see no issues during the change overs though I only tried it for about 10 minutes in my living room.
The RTH can be set to LAND when the battery is low instead of RTH to keep it from trying to fly through the ceiling. |
