Labroides
Flight distance : 9991457 ft
ZGON Posted at 12-17 06:41
Thanks guys. I generally stay well under max flight altitude, this time my eagerness to get to a monument got me!
Below is an example of this happening when I was no where near max flight altitude, it's quite possible it's interference. However I've flown here hundreds of times in my Mini2 and Phantom3 with no other issue. I was worried it might be the IMU error that have experienced. But i don't think it's it.
There's nothing unusual in your data.
It just shows is that wind affects your drone.
If you fly directly into the wind, it will affect your drone's max speed the most.
And wind speed up higher is greater.
Imagine swimming against a current.
You can swim at 4 mph, but if you swim against a current of 3mph, your speed over the ground is reduced to 1 mph.
It's the same for your drone except the air current is faster up higher. |
