fans031ff210
Flight distance : 16270 ft
Singapore
Decided to do a hover test after loading new firmware. Mini took off just fine but soon starting drifting right. I brought it back but then it started drifting backwards fairly fast. I chopped the throttle, but too late. The Mini flew into my hand. After wiping off the blood, I did an inspection of the Mini. One prop screw was loose. Word to the wise: throughly inspect your aircraft prior to takeoff...especially the prop screws. That is all.
BTW, my hand is fine...just minor cuts.
