Cannot Load Firmware List
1275 2 2020-12-22
ianhylands
Hi, I've searched the forums and found this topic many times, and tried all of the solutions, however none seem to be working.
I'm using DJI Pro Assistant for Ronin V2.0.2 to try to update the firmware on my DJI Ronin S, Serial Number is OEMDFCS00D02FN on a PC running Windows 10 Pro Build 19042.685
THe DJI Assistant can see my Ronin S no problem, however it won't show me the firmware updates giving me the error "Cannot Load Firmware List" Screenshot attached
I've tried my normal internet connection at home, my connection at work, and tethering to my phone hotspot as suggested by several people. I've tried it with my firewall turned off, doesn't make any difference. My log from my most recent attempt is below.
Please advise me how to proceed. By the number of posts about this it seems to be an ongoing issue, is there another way I can update the firmware besides Assistant?
Screenshot
Screenshot
LOG
[08:44:47.349][DJIIdentifierMgr    ] Device Arrive COM3
[08:44:47.349][DJICmdIo            ] open COM3
[08:44:47.550][DJISerialIo         ] Open COM3 success!
[08:44:47.550][DJIIdentifierMgr    ] open device succeed
[08:44:47.571][gen_idf_COM3        ]  GetModuleActivateStatus1 Error! ErrorId : 2
[08:44:47.583][DJIIdentifierMgr    ] [Center_board , hg700        , 01.00.06.66  ], App
[08:44:47.583][DJIDeviceMgr        ] device service ready! COM3
[08:44:47.592][DJIDeviceMgr        ] DevArrival, Center_board, hg700, ,01.00.06.66, 346bbcde7e78d76d664b229e28be382ece6c6d0b, normal
[08:44:48.040][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[08:44:48.073][DJIWebFileGetter    ] [OnFinish]reply statusCode=201
[08:44:48.320][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[08:44:49.228][DJIDeviceMgr        ] Refresh DevArrival, Center_board, hg700, ,01.00.06.66, 346bbcde7e78d76d664b229e28be382ece6c6d0b, normal
[08:44:49.251][DJIDeviceMgr        ] Refresh DevArrival, Center_board, hg700, ,01.00.06.66, 346bbcde7e78d76d664b229e28be382ece6c6d0b, normal
[08:44:49.426][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[08:44:49.517][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[08:44:49.572][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[08:44:49.578][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[08:44:49.690][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[08:44:49.690][DJIServerApi        ] [ApiV2UserUsertype]url=https://mydjiflight.dji.com/api/v2/user/user_type||device_token=f756bf0a-0901-4c6d-b29c-2c84cd8a98ea
[08:44:49.865][DJIWebFileGetter    ] [OnFinish]reply statusCode=201
[08:44:49.865][DJILogin            ] user type:
[08:44:52.868][DJIDeviceMgr        ] Refresh DevArrival, Center_board, hg700, ,01.00.06.66, 346bbcde7e78d76d664b229e28be382ece6c6d0b, normal
[08:44:52.901][DJIDeviceMgr        ] Refresh DevArrival, Center_board, hg700, ,01.00.06.66, 346bbcde7e78d76d664b229e28be382ece6c6d0b, normal
[08:44:52.960][DJIUpgradeMgr       ] ServiceUrl : https://mydjiflight.dji.com/links/links/hg700
[08:44:52.960][DJIUpgradeView      ] userType :
[08:44:52.970][DJIDeviceInfoEnumera]   5%  1/17 GCU(7)
[08:44:52.970][DJIDeviceInfoEnumera]  11%  2/17 Battery(0)
[08:44:52.976][DJIDeviceInfoEnumera]  17%  3/17 Yaw(3)
[08:44:52.976][DJIDeviceInfoEnumera]  23%  4/17 Bluetooth(1)
[08:44:53.002][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[08:44:53.102][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[08:44:53.134][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[08:44:53.160][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[08:44:53.474][DJIDeviceInfoEnumera]  29%  5/17 Focus_Wheel(1)
[08:44:53.775][DJIDeviceInfoEnumera]  35%  6/17 IMU(0)
[08:44:53.775][DJIDeviceInfoEnumera]  41%  7/17 Pitch(1)
[08:44:53.775][DJIDeviceInfoEnumera]  47%  8/17 Roll(2)
[08:44:54.990][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: LCD(5:6)
[08:44:54.990][DJIDeviceInfoEnumera]  52%  9/17 LCD(6)
[08:44:54.990][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: LCD_flash(5:3)
[08:44:54.990][DJIDeviceInfoEnumera]  58% 10/17 LCD_flash(3)
[08:44:54.990][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: On-board Mount(5:0)
[08:44:54.990][DJIDeviceInfoEnumera]  64% 11/17 On-board Mount(0)
[08:44:54.990][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Focus Handler(5:4)
[08:44:54.990][DJIDeviceInfoEnumera]  70% 12/17 Focus Handler(4)
[08:44:55.000][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: RC Handler(5:5)
[08:44:55.000][DJIDeviceInfoEnumera]  76% 13/17 RC Handler(5)
[08:44:55.000][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: EXT_GPS(5:1)
[08:44:55.000][DJIDeviceInfoEnumera]  82% 14/17 EXT_GPS(1)
[08:44:55.000][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Focus Motor(31:5)
[08:44:55.000][DJIDeviceInfoEnumera]  88% 15/17 Focus Motor(5)
[08:44:55.000][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Iris Motor (31:6)
[08:44:55.000][DJIDeviceInfoEnumera]  94% 16/17 Iris Motor (6)
[08:44:55.000][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Zoom Motor(31:7)
[08:44:55.000][DJIDeviceInfoEnumera] 100% 17/17 Zoom Motor(7)
[08:44:55.000][DJIDeviceInfoEnumera] GCU            (5 :7) Ldr : 01.00.03.00 App : 01.00.06.66
[08:44:55.000][DJIDeviceInfoEnumera] IMU            (4 :0) Ldr : 09.01.00.17 App : 00.05.11.89   GB09
[08:44:55.000][DJIDeviceInfoEnumera] Pitch          (4 :1) Ldr : 01.00.00.03 App : 01.00.00.10   GB09
[08:44:55.000][DJIDeviceInfoEnumera] Roll           (4 :2) Ldr : 01.00.00.03 App : 01.00.00.10   GB09
[08:44:55.000][DJIDeviceInfoEnumera] Yaw            (4 :3) Ldr : 01.00.00.03 App : 01.00.00.10   GB09
[08:44:55.000][DJIDeviceInfoEnumera] Bluetooth      (7 :1) Ldr : 00.00.00.04 App : 05.04.00.00   BLE CC2540
[08:44:55.000][DJIDeviceInfoEnumera] Focus_Wheel    (6 :1) Ldr : 01.00.00.00 App : 02.02.00.07
[08:44:55.000][DJIDeviceInfoEnumera] LCD            (5 :6) device no reply, request timeout!
[08:44:55.000][DJIDeviceInfoEnumera] LCD_flash      (5 :3) device no reply, request timeout!
[08:44:55.000][DJIDeviceInfoEnumera] On-board Mount (5 :0) device no reply, request timeout!
[08:44:55.000][DJIDeviceInfoEnumera] Focus Handler  (5 :4) device no reply, request timeout!
[08:44:55.000][DJIDeviceInfoEnumera] RC Handler     (5 :5) device no reply, request timeout!
[08:44:55.000][DJIDeviceInfoEnumera] Battery        (11:0) Ldr : 00.00.00.01 App : 04.73.05.07   HG700BATTERY
[08:44:55.000][DJIDeviceInfoEnumera] EXT_GPS        (5 :1) device no reply, request timeout!
[08:44:55.000][DJIDeviceInfoEnumera] Focus Motor    (31:5) device no reply, request timeout!
[08:44:55.001][DJIDeviceInfoEnumera] Iris Motor     (31:6) device no reply, request timeout!
[08:44:55.001][DJIDeviceInfoEnumera] Zoom Motor     (31:7) device no reply, request timeout!
[08:44:55.001][DJIServerApi        ] [LinksLinks]url=https://mydjiflight.dji.com/links/links/hg700||productId=versionlistHG700
[08:44:55.208][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[08:44:55.255][DJIWebFileGetter    ] NetworkError: 3
[08:44:55.255][DJIWebFileGetter    ] [OnFinish]reply statusCode=0
[08:44:55.255][DJIWebFileGetter    ] Reply error :3
[08:44:55.255][DJIWebFileGetter    ] Reply error string :Host terra-2-g.djicdn.com not found
[08:45:54.160][                    ] release class DJIIdentifierInterface<class DJISecondIdentifier>
[08:45:54.160][                    ] Release DJIIdentifier.
[08:45:54.161][                    ] release class DJIIdentifierInterface<class DJIGeneralIdentifier>
[08:45:54.161][                    ] Release DJIIdentifier.
[08:45:54.161][gen_idf_COM3        ] release class DJIIdentifierInterface<class DJIGeneralIdentifier>
[08:45:54.161][gen_idf_COM3        ] Release DJIIdentifier.
[08:45:54.161][DJISerialIo         ] Free COM3 success!
2020-12-22
ianhylands
UPDATE
The DJI Pro Assistant for Ronin will not install by default on macOS Catalina, however I used the workaround found here https://forum.dji.com/forum.php? ... D582%26typeid%3D582 and managed to get the Assistant installed on my mac. It worked perfectly once installed with no problem downloading and installing the firmware update.
Not sure what the issue is with the PC version of the app, it wouldn't connect on the same network no matter what I tried. This won't help those with a PC, but for those with a Mac this works!
2020-12-22
DJI Wanda
Hello, thank you for the updates and we are glad to see the the firmware download was successful. We are sorry for bringing this software issues. Our engineers are still working on the compatibility of the macOS Catalina. Once we have other solutions, we will update on the download section from the product page.
Thank you again for the information above.
2020-12-24
