New FAA Remote Pilot Rules
784 14 2020-12-29
AntDX316
Flight distance : 3394731 ft
https://www.faa.gov/news/press_r ... I6QOgegJfh_iLH7QUck
1. Operate a standard Remote ID drone that broadcasts identification and location information of the drone and control station;
2. Operate a drone with a Remote ID broadcast module (may be a separate device attached to the drone), which broadcasts identification, location, and take-off information; or
3. Operate a drone without Remote ID but at specific FAA-recognized identification areas.
2020-12-29
A Crawford
Will dji provide something that will allow the mavic pro 2 to meet these requirements?
2020-12-29
John Ski
Will DJI have something that will allow the Mini 2 to meet the FAA requirements?
2020-12-29
Ruzhye
Flight distance : 795640 ft
I wonder if the Air 2 will be able to transmit, or continue to only receive ADS-B in?
2020-12-29
DAFlys
All DJI drones currently transmit most of this information,  you need DJI Aeroscope to be able to receive it though.
2020-12-30
NightThunder
Flight distance : 106020 ft
Ruzhye Posted at 12-29 13:10
No need to transmit ADS-B. In fact the FAA forbids this except in rare instances and requires a waiver. IMO it was a brain dead idea to even consider ADS-B out in the first place.
2020-12-30
Maxi3D
Flight distance : 307621 ft
A Crawford Posted at 12-29 10:37
DJI will add it the Mavic 3 pro.
2020-12-30
Maxi3D
Mavic Air 2's ADS-B is out only.
2020-12-30
NightThunder
Maxi3D Posted at 12-30 13:22
No, it is not ADS-B "out". It is ADS-B in only. You can only "receive" ADS-B signals, not transmit. That is the current state of affairs.
If there are enough requests (more than 2) I will explain further as to why this is.
More importantly what this means is that remote ID for most drones will require a firm ware update and small small updates to the controller software. No hardware changes.
BTW: DJI has already added a software placeholder for remote ID to the Go4 app for M2. Probably others as well which I don't own so I cannot verify.
2020-12-30
JohnLietzke
Flight distance : 3125968 ft
This ADS-B in the Mavic air 2 appears to only be a ADS-B receiver. It is unlikely the hardware will support ADS-B transmission.
2020-12-30
Ruzhye
NightThunder Posted at 12-30 19:00
Thank you, that makes sense.
2020-12-31
hallmark007
Flight distance : 9827923 ft
Number 1, I’m not sure how this will go down and if pilot will be at risk of being harassed, we do know dji originally did not want FAA to go this route, but it looks like they are going to broadcast anyway. I do remember a certain Hedgetrimmer telling all and sundry that the FAA would 100% not implement this, well must be eating his words now....
2020-12-31
NightThunder
I should also mention that ADS-B for drones has NOTHING to do with remote ID. Remote ID is a requirement to broadcast from the UAV directly it's identity, location, etc. and will use current 2.4GHz and 5GHz radio frequencies for broadcast. If the final data packet (format, elements, etc.) has been established I have not seen that published anywhere. Everything I have seen has been conjecture at best. And now with dropping the need for internet connection, the packet format must change as there is not longer a need or ability to establish a "Session ID" element. This is a big deal. Makes things much easier.
Another thing is that as proposed only qualified (my word) authorities will be able to trace a drone back to it's owner so we will have a little bit of anonymity. As far as take off location in the clear that seems to be the current specifiaction. To me that is troubling and should NOT be in the clear and is relatively easily to obfuscate. Simply change RTH to RTC (return to controller) and get up off your ass and move to a new location. There is no requirement to continually update the location of the controller (take off point?) and there is no way to detect where the operator eventually decides to land the UAV rendering this information dubious at best and useless at worst.
IMO Remote ID is still a mess but steps are being taken in the right direction. Dropping the need for ineternet connection removes the ability of having centralized supplied session IDs which totally removes the cost and complexity of establishing USS providers is one such step. Another is that the public will not have access as to who is flying a specific UAV.
Lots of work still for the FAA.
2020-12-31
AntDX316
NightThunder Posted at 12-31 12:10
Return to Controller?  The Controller GPS location is way off unless the manufacturers install each controller with a GPS.
2020-12-31
NightThunder
AntDX316 Posted at 2020-12-31 22:54
My bad.  Perhaps I should have said "Return to Me" where the home point is set to the dynamic GPS location of the smart device (i,e, phone) connected to the controller. This of course assumes you have a device that supports GPS and GPS is turned on said device and is connected. At least that is how my M2P works. Can't say about other DJI Drones though.
2021-1-1
