ross
Flight distance : 248914 ft
Good Evening,
My Phantom 3 has stopped recording images. I am unsure exactly when this started as I haven't checked the memory card for a few flights.
Flight is fine and I see the normal image through the application however I cannot record any images or video. If I try and take a photo it makes the camera noise and the circle around the “button” rotates for about 15 seconds. During this time the camera feed disappears and after about 10 seconds says No Signal. It then comes back a few seconds later. I then get 3 beeps, 1 standard and then 2 quicker. No image is recorded. If I select the video mode the slider button moves across but the camera feed disappears, I then get the no signal and three beeps and when the image comes back it goes back to camera mode and once again no image is recorded.
I have upgraded to the latest firmware and I have tried different SD cards as well as reformatting. I have also reinstalled the android app and reset all the settings.
Please help. Thanks all. |
