Skynet5
Flight distance : 20253 ft
Loving this drone.
Opened it last night and updated the the controller and drone firmware.
Had a good play around and when I switched over to battery 3 and I noticed it wanted to update the battery firmware so I did it.
App showed progress and then said complete and the drone had turned off. Turned it all back on and great all working.
Then I tried to do battery 2 (i have 3 as part of the combo). Struggled to get it to trigger, no clue if it was updated already perhaps and didnt need it. I shut everything down and powered back up and bingo it asked. So said ok, but the progress never moved from 0%, but the drone had turned off. The drone was at roughly 48% battery life.
No idea if it did it or not, and there appears to be no way to check.
I havent mentioned battery 1, but that certainly hasnt asked to be updated ... not sure if the drone firmware update updates the battery insitu at the sametime?
So out of 3 batteries:
1 - presumed is updated as part of drone update as it was plugged i
2 - not sure of status
3 - definitely updated.
Thoughts?
