pdu
Flight distance : 155801 ft
Switzerland
I can give a little bit of insight about what I tried and how I (partially) solved some problems.
RavenEye and HDMI cable
There is indeed a problem with plugging in the provided HDMI cable because the thick part of the plug does not bend, thus putting stress on the camera's HDMI port. I got an idea from https://www.youtube.com/watch?v=RSYB-S4Y8Xc and ordered L-Shape cables off of ebay (they haven't arrived yet, unfortunately). But this should solve the problem.
Another way that might solve the problem is to put more weight on the front of the quick-release plate. There's holes for screws to e.g. attach a lens stabilizer (if you have the pro combo) and I guess you could also put some counter-weight thumbscrews there, which would allow you to move the camera more "backward" and thus not having the gimbal arm get in the way of the HDMI cable. There's also counterweight kits that you can put under the quick-release plate. You could maybe have a look at the counter-weights from SmallRig as they produce various parts for DJI products
As a side note, this is only a problem if you're using small EF-M lenses, like e. g. the 15-14 kit lens or the 22mm lens. If you want to go for bigger lenses (I put a viltrox speedbooster/adapter on it with a sigma 24mm f/1.4 EF lens), the problem is gone as well because of the different weight distribution. I'm not sure if the viltrox adapter together with my canon 50mm will also work here.
RavenEye and cable length
One user mentioned that the cable is not long enough to reach the port. Well, there's two possible solutions to this. 1. Buy a longer cable. Or, what I did, 2. turn the RavenEye 180° and mount it that way on the gimbal arm, your cables will be long enough that way.
RavenEye and upwards balancing
As I described in my initial post; If you use small EF-M lenses (15-45mm kit lens or 22mm lens) and have the RavenEye mounted on the gimbal arm, you don't have enough counter-weight on top of the camera when you try to balance pointing the camera upwards. This problem is gone with bigger lenses (not tried with e.g. the canon EF 50mm and viltrox adapter, but certainly no problem with my sigma 24mm f1.4 EF lens).
As a workaround, I bought a cold shoe adapter for putting e.g. a monitor or LED light on top of the camera, and made sure that it is not just plastic but that is has a bit of weight (metal ball head, check the SmallRig products as well). This solved the balancing problem for me.
Hope this helps. |
