Can anyone recommend a variable ND Filter?
12Next >
5680 48 2021-1-14
DAFlys
Can anyone recommend a variable ND Filter for the Mini 2,   I have the freewell one for the Mavic 2 pro which is superb but I cannot find one for the Mini 2.
ta
2021-1-14
George210477
Flight distance : 2676129 ft
Romania
I dont think there is NVD filter for Mini/Mini2....I have worked with Freewell and PGYTech, but PolarPro is much more quality then this ones. At this point I advice you to take ND Filters 4/8/16, will be enough. Also in 30 minutes you will not have such major change to get the filter off...even with NVD you need to get the drone back...so no point...I have PolarPro NVD for MA2, most times in daytime stay between 4 to 16, if 32 is required i just go up with FPS and SS in order to remain 16 and the 180 degrees rule. Usually is enough to go to 50 FPS and 1/100 SS, as normally I use 25 fps and 1/50 SS. Is about being versatile in order not to bring the drone down each time you get sun instead of clouds ...and at post production just reinterpret the footage accordingly.
2021-1-14
DAFlys
George210477 Posted at 1-14 02:58
Thats a shame,  Have the Variable ND filter of the Mavic 2 Pro and its just so much more convenient to set than having to take off and re install different filters and test which is the right one for the conditions, compared to the variable where I can just rotate the lens.
2021-1-14
George210477
Romania
DAFlys Posted at 1-14 03:37
Agree...but also the gimbal on Mini is more fragile than M2P and MA2...NVD have more weight than normal ND filters...and most quality NVD are made from Stainless Steel sustaining 2 real glass sheets in an ABS support, not just plastic...I believe is more a construction limitation, than a choice not to make NVD for MM2.
2021-1-14
George210477
Romania
Also try Polar Pro Filter Guide...you can find older versions on Net, is helping you decide related to filter used.
I use the following strategy, maybe it helps (It takes me 5 seconds to set the proper Stops on NVD, until it is syncing the satellites, I'm ready to flight):
I have a P30 Pro Huawei, I  make a photo of what i want to record with the drone...than I just see the Info from picture made, as I have defined fixed ISO and Fixed AP (i mostly use MA2 fixed AP)...so is very easy to calculate from the SS I get in picture the Stops needed in order to get my targeted SS on drone, to be 180 degrees rule.
2021-1-14
DAFlys
George210477 Posted at 1-14 03:57
I have a light meter app I often use. But this often quite a difference looking down vs looking forward so it’s convenient for the vnd to make a quick change.
2021-1-14
Through The Lens
Flight distance : 372992 ft
I use the freewell gear nd filters, and they are great. (I have them for the 1, but its marketed for the 2 too.)
2021-1-14
Montfrooij
Flight distance : 2560453 ft
Maybe the M2 is not strong enough to hold a double layered ND filter.
2021-1-14
DAFlys
Through The Lens Posted at 1-14 06:07
From my research the Mini 1 and 2 are the same size, but I cannot find a Variable ND from freewell,  do you have a link?
2021-1-14
DAFlys
Montfrooij Posted at 1-14 06:26
Im thinking the same,  but they could do what moment did with the anamorphic lens and use a counter weight.
2021-1-14
lordziemniak
Poland
DAFlys Posted at 1-14 09:20
Here you go US $59.99 | Freewell Bright Day - 4K Series - 4Pack Filters Compatible with Mavic Mini/Mini 2 Drone
https://a.aliexpress.com/_mqm7BvB
2021-1-14
DAFlys
lordziemniak Posted at 1-14 09:32
Thanks,  but they are not variable ND filters.
2021-1-14
DAFlys
Heres an example for the Mavic 2 pro,  Im looking for the same for the mini.  You'll see you rotate the ring to set how many stops you want.
https://www.amazon.co.uk/Freewel ... 8WK?ref_=ast_sto_dp
2021-1-14
Montfrooij
DAFlys Posted at 1-14 09:21
We'll see who jumps in.
2021-1-14
DAFlys
Montfrooij Posted at 1-14 09:57
I hope there is one out there.   Did you get any ND filters yet?
2021-1-14
sbonev
Flight distance : 3665279 ft
Switzerland
DAFlys Posted at 1-14 09:47
https://www.amazon.co.uk/Freewell-Variable-Neutral-Density-Compatible/dp/B07W4GF8WK?ref_=ast_sto_dp
there are zero variable nd filters compatible with the mini/mini 2, most probably because of the size of the gimbal and the limitations of weight it can withstand of no more than 1.30 or so gr...
there are nd and nd/pl filter sets from different brands. tiffen are claimed one of the best. they have a set of nd/pl ones. i personally use pgytech and recommend them as they are not circular and cover the whole camera. the circular ones cause lens flares at certain angles, hence i won't recommend any of them.
2021-1-14
DAFlys
sbonev Posted at 1-14 10:08
Thanks. I'll keep looking incase some company release them in the future.
2021-1-14
Montfrooij
DAFlys Posted at 1-14 10:04
Not to this date.
I did not use ND filters a lot.
They interfere with the photography needs too much. (blocking light)
And I personally feel their effect is very very very much overrated.
Sometimes it feels like it is the first thing that comes to mind when people want to make 'good footage'.
Of course you can see some difference in some situations, but there are tons of other factors that make your video stand out.
A bit of motion blur is just the last 5% or so.
So unless I really need that 5% I won't buy them.
Flying slow and smooth, good composition, good lighting, good story.
If you get those right, I doubt many people will complain about a little bit of sharpness in the frame.
But, maybe with the M2 (that seems a bit less equipped for stills) I might change my mind because I don't take that much stills.
So far I even have to find time to fly.
I have not been very excited about it lately.
Too much hassle about rules etc. and negative publicity.
And it takes way too much of my free time (time I don't have during the day).
In fact, I even considered selling my M2....
But I decided to wait for the summer and see if I can get inspiration.
2021-1-14
DJI Stephen
Hello there DAFlys. Thank you for reaching out and for the inquiry. Since this is a 3rd party accessory for the DJI Mini 2. I hope that you will get the best recommendation from our fellow DJI co pilot on what and  where to purchase the said variable ND Filter and share there experiences using it as well. In addition, you may try check our DJI Where To Buy platform on this link ( https://www.dji.com/where-to-buy ) to see if the said variable ND Filter are available. Thank you and please be safe always.
2021-1-14
DAFlys
Montfrooij Posted at 1-14 10:50
Not to this date.
I thinking for the M2 its more important as its got a fixed aperture.
2021-1-15
Montfrooij
DAFlys Posted at 1-15 00:47
If you do photography, I would not mind.
It is counter productive for photography.
(unless you are going for long shutterspeeds of course)
2021-1-15
DAFlys
Montfrooij Posted at 1-15 01:28
Theres certainly a sweet spot for shutter speed,   especially for landscapes if its too fast things start looking a bit rough.
2021-1-15
Montfrooij
DAFlys Posted at 1-15 01:32
So far I have to find evidence that you can get 'too fast' shutterspeeds for photography.
I more worry about motion blur and high ISO than a fast shutterspeed.
Did you do testings that show there is a degradation after a certain shutterspeed (with the same aperture of course, since that can cause softness because of diffraction etc.)
2021-1-15
DAFlys
Montfrooij Posted at 1-15 01:48
Something I learnt very early in photography,  but you can find reference of it -
https://www.makeuseof.com/tag/4-common-shutter-speed-mistakes/
In general, the faster your shutter speed, the more it will freeze motion -- and the degree of frozen motion will depend on how fast your subject is moving. ... Most of the time, however, you'll want to avoid too fast of a shutter speed because it can look unnatural.
2021-1-15
Montfrooij
DAFlys Posted at 1-15 01:52
I know about that theory.
To my best knowledge this is mostly aimed at capturing moving subjects that are relatively close to the lens (fill up a large portion of the frame) and I have found no examples of this effect in landscape shots or other photo's that were taken from a larger distance.
But I could be wrong, hence the question if you have done testing with drone shots.
2021-1-15
DAFlys
Montfrooij Posted at 1-15 01:58
For my landscapes with my DSLR I have seen it,  too high an iso and things log overly sharp and if you zoom in the detail is not as good.   This is of course at the extremes in the 1/4000+ area.
2021-1-15
Montfrooij
DAFlys Posted at 1-15 02:03
For consumer drones, I think you are good at all shutterspeeds above 1/100s
The drone won't capture a lot of details anyway with the cheap lens in front of the tiny sensor .
So shutterspeed 'sharpness' is not an issue you will run into very likely.
There are other bottlenecks in the camera system that have greater impact on the image that we can't control.
That is my theory at least, so I could be wrong, (but I would love to see proof of it before diving into ND filters) .
2021-1-15
DAFlys
Montfrooij Posted at 1-15 02:14
I use a ND on the M2P all the time,  I'll see how I get on when I finally have the mini 2 and will then decide on whether I want one of not.
2021-1-15
Montfrooij
DAFlys Posted at 1-15 03:53
I'm curious if you can spot the difference with the MP.
Same situation, same aperture, different shutterspeed.
2021-1-15
sbonev
Switzerland
Montfrooij Posted at 1-15 03:57
i have tried that with my mini right after i got my nd filter set.. even with shutter speeds below 1/100 there is no visible difference with or without nd filter. you have to be really pixel peeping to notice something really small i guess. Overall in some situations the nd can be helpful when movement, or really contrasty skies and a lot of clouds.
2021-1-15
Montfrooij
sbonev Posted at 1-15 04:04
Thanks.
For videography it certainly makes a (small) difference, but for photography I'm not sure I want to invest in them.
2021-1-15
DAFlys
I have the Mavic 2 Pro so have a variable aperture to play with.
2021-1-15
Montfrooij
DAFlys Posted at 1-15 05:03
That is super handy.
I know the aperture does have a sweet spot with every lens.
I have tested that with my lenses to know what my optimal setting is (when I need the best sharpness).
Most of the time however I do use aperture for either a bit larger DOF or to get the most light in.
2021-1-15
DAFlys
Montfrooij Posted at 1-15 05:49
They have been some big arguments here over the sharpest aperture on the M2P. Lol
2021-1-15
Montfrooij
DAFlys Posted at 1-15 06:19
It is always debatable as there are so many factors to consider.
2021-1-15
DAFlys
Montfrooij Posted at 1-15 06:25
Indeed but it’s amazing how heated it can get.
2021-1-15
Montfrooij
DAFlys Posted at 1-15 06:34
It is amazing indeed.
You see it all the time.
2021-1-15
Through The Lens
DAFlys Posted at 1-14 09:45
Oh, just reread your title. Yep, no Variable ND filter for the mini 1-2 ive seen on the market. Sorry!
2021-1-19
DAFlys
Through The Lens Posted at 1-19 05:57
lol - no worries,  Ive searched long and hard and not come up with anything either.
2021-1-19
Through The Lens
DAFlys Posted at 1-19 07:42
2021-1-19
12Next >
