DJI Paladin
Hi there. We do apologize that you are having issues with your unit. Can you please try to check if the aircraft status is normal? Also, please try to perform a gimbal calibration and then restart the aircraft to see if the issue persists. If yes, I'm afraid that you may consider sending the unit in for a proper diagnosis. You can contact our support team to start up a ticket at https://www.dji.com/support . Also, the warranty can be applied depending on the outcome of the damage assessment including the warranty period of your unit. Thank you for your understanding and support. |
