BORRERO.MD
Flight distance : 774534 ft
Colombia
lannes Posted at 1-25 02:41
This vibration occurs when the drone is flying straight and level, it's not banking when you would see camera gimbal tilt to compensate for the bank and hit the lens hood clip ?
If you try to simulate the bank for it hit the lens hood it's about 46 degrees of more, on my mini once you go past this gimbal locks in place back in the horizontal positon
Good point. It's hard to tell. I tested the hood yesterday, in better environmental conditions (basically, lighting) and the gimbal did make a weird jerky movement while the hood was on, but only once and for a short period. However, I didn't take the wind into consideration nor any aerodynamic effects. The problem never occurred after I took the hood off though. Total disclaimer here, I was using my Freewell ND/PL filters the first time the problem happened, but I basically don't fly without one on and haven't had issues when using only the filters, without the hood, both before and after the first incident. Maybe it's a combination of both some aerodynamic effects + an extra weigh on the gimbal due to the ND/PL filters? I do calibrate the gimbal everytime I swap the filters. I bet that helps preventing such issues caused by the minute, yet not null, weight of the filters. |
