Niko from DJI Technical Support said 27.3.2020 under General Support. 1) Pushing both sticks to the inner or outer bottom corners (CSC): It means that the motors will stop when performing CSC in any situation. Conduct CSC, the drone will first turn around, and then stop after 2 seconds. This operation is very dangerous and is not recommended for users. 2) Choose CSC Maneuver (for use in emergencies only) in the app: It means that if the drone is at an abnormal state (for example, when the app detects that the drone is not working normally, or the drone has hit something during the flight, or the motor stops running due to obstacle, etc.), pushing both sticks to the inner or outer bottom corners will let the motor stop. It is recommended that the user choose this technique. Can someone please confirm the following thanks: Do I understand this correctly that as per:
1. The motors will stop in 2 sec in any situation if emergency is not selected. But as per:
2. The motors will not stop when flying and you accidentally do an CSC, if CSC is not set to “emergency only" and everything is normal when flying and drone is not detecting anything abnormal. In item 2. This to me means that if you have set CSC to emergency only and the app has not detected anything abnormal, motors would not stop if you done an CSC? If so then in contradicts item 1. Sorry, but I do not see that there is any difference between the 2 statements and would appreciate if someone could assist me in understanding this as it is very important to know what is what. Perhaps I do a thinking error in my head? Thanks.
