djiuser_MiiZ9vc7ygv4
Latvia
Jackie Nguyen Posted at 2021-12-4 03:17
my joystick is messed up physically. You can disable the joystick by going in the joystick option on your gimbal, then go to the speed menu, then scroll down to custom and adjust the speed to 0 to disable the joystick. Hope this help you. Problem solved, haved the same issue, with gimbal moving up after yoistic relase, only if i push up and down then it stoped. Tryed to change direction of joistic to ensure thatbproblem is physical not in settings. And problem is the same only camera now moves down. Then i tryed to spray liqui moly elektronikspray in to yoistic without removal anything. Then pushed joistic to all directions about 30sec to clean and IT WORKS!!! I think that any electronicspray will work. Hope it helps for you all |
