how to setup auto power of on dji pocket 2 ??
2096 1 2021-2-21
jeanjohnny
Hi All,
i recently purchased a DJI pocket 2 with the last available firmware  (01.03.00.10) , and i would like it to stay always on  instead of  powering off after some minutes.
( this happens even when connected to a external powerbank via usb-c ) .
I saw on the user manual that i should  be able to setup the auto power off in the system menu , but i don't see it at all on my dji . When i press the system icon ( clockwork symbol )
i only get:
full screen
Storage
FT ( selfie)
Accessories
callibration
antiflicker
key tone
more  ->
   language
   reset
   Device Info
as it been remove from the menu ?
Is it possible to disable the auto power off  ?
regards,
jean
2021-2-21
Superior Videos
Hi Jean. I don't know how old this thread is but I will comment anyway.
I have found the only way around this is to have the camera connected to the app.
You will need a large capacity powerbank to power the camera and phone.
Testing I have done would suggest these requirements.
10,000 mah power bank with usb c and usb a outputs.
You will need to plug in a small usb light or something that draws constant power to prevent the power bank from turning off when the camera is fully charged.
Connect the camera via the usb c and the light to the usb a
You should get a number of hours of recording when plugged in.
The pocket 2 tends to trickle some of the power from the internal battery and then the power bank takes over at around 89% of the camera battery.
These measures are a real pain but seem to be effective for me.
I have mine set up on a small lighting tripod with smart phone clamps so it is a complete rig.
Good Luck.
2021-10-5
