wiljan5560
Flight distance : 81821 ft
Hope this can be solved,
So i have installed App 1.2.4 on my Android 11 Samsung S10+ phone. Today I have been flying with the mini 2, and the only issue I have seen, is the little dot from the operator on the map. This dot is not pointing towards the drone as it should be. If I almost turn away and from the opposite direction then this little blue controller arrow is pointing towards the drone.
However when I truly look at the drone and my controller is pointing towards the drone as well, then this little blue controller arrow is really pointing in a wrong position....What is your view on this and how can this be solved quickly?
thanks and regards
